Sub question
Username: Msully701
Stratford, Connecticut US
Post Number: 12
ok, I plan on getting this amp:http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=18797%26item%3D5764159323 %26
and these subs:http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=39777%26item%3D5764366029 %26
this is the wireing(2 woofers, dual 4 ohms x 2): http://www.rockfordfosgate.com/rftech/wiringwizard.asp?WoofQty=2+woofers&WoofImp =Dual+Voice+Coil+-+4+ohms+x+2&image.x=14&image.y=7
I was wondering if this wireing(wiring option#1) would work for the amp and subs(and give 600 RMS watts to each speaker) and if theres any special wiring I can buy instead of splitting and wiring wires together? I have gotten a few opinions but im dropping about a g so I dont wanna get something that wont work so I want as much opinions on it
aim:Msully 70
Username: Jmloughrey
Farmington, CT
Post Number: 1108
you're gonna need to get the Dual 2 ohm subs in order to create a 2 ohm load for that amp to produce its maximum power
Username: Msully701
Post Number: 15
I was told that if I wired them for a 1ohm load that they would be maxed out is that true?
