Eaveguard for sound deadening?
Username: Jwbulger79
Florida
Post Number: 314
this was mentioned in a thread in another section, but i wanted to start it's own thread in this section so it doesnt get lost.
anyone have any experience with this stuff? looks like it could be a good option for cheap sound deadening. any experience, pictures, links, etc. please post. thanks.
https://www.ecoustics.com/electronics/forum/car-audio/127799.html
Username: Fishy
TamaracFt.Laud, FL USA
Post Number: 710
Dynamat, Edead, etc does have some "damping" characteristics as in that it resists motion like a shock absorber, but as far as I know the main way it works is by simply adding mass to whatever you stick in on which reduces the resonant frequency to a point where it doesn't audibly vibrate. I saw a thread somewhere where some guy just siliconed particle board to his quarterpanels for the same effect. Regardless there's nothing magical about Dynamat except maybe when it comes to heat resistance and installation ease.
Looks like this Eaveguard is pretty much the same stuff. If it'll stay stuck it should work great.
Just gotta find what brand is sold at Home Depot so if I ask someone there they'll know what the heck I'm talking about.
-Fishy
Username: Jeremyc
Kunsan AfbSouth Korea
Post Number: 562
Peal and seal I beleive its in the roofing department
Username: Minime
Portland, OR
Yeah, just ask if they have rolls of shingle underlayment (yes roofing dept).
Username: Chinaman_87
Houston, Tx Usa
Post Number: 29
yeah i just bought some today (peel and seal)
'6 x 25' for 13.50
Florida
Post Number: 333
you mean six inches by twenty-five feet right? so 12.5sqft, or 1.08 per sqft.
fishy and i live in 'ole sunny florida. nobody carries that stuff down here - just hurricane shutters.lol:-) (kinda)
Username: Fishy
Tamarac Ft.Laud, FL USA
Post Number: 737
I didn't think so.
-Fishy
Username: Goon
Post Number: 48
damnit i live in florida...why dont we have that stuff down here? i havea shingle roof. argh.
Username: Minime
Portland, OR
Post Number: 10
You can always order it online. That's what I did... just got it a couple hours ago.
http://doitbest.com/shop/product.asp?dept_id=4261&sku=119458
Username: Sldonmtns
Ca
Nick, I was wondering how this eaveguard stuff is working for you? Also, does it say what the max temp is that it can handle?
thanks
Username: Minime
Portland, OR
Post Number: 39
The datasheet mentions something about 110 degrees F, but that's in the section about storage while it's still in the box so I don't know. I haven't got around to putting it in the car yet, but it seems like it'll work okay. My only concern is that the back is gritty, kinda like sandpaper, so I don't know how well it'll do layered.
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 7751
shouldn't really need to layer it. the only thing it has to do is stick to the metal to change the sympathetic frequency of the sheet metal and absorb resonance.
If you want to do a more solid job, use a spray-liner.
Username: Fishy
Post Number: 1026
fishy and i live in 'ole sunny florida. nobody carries that stuff down here - just hurricane shutters.lol (kinda)
Actually I found some stuff at Lowes. I forget the brand name. It was called Water Shield or Guard or something. Well anyways it was 64 dollars for 100 sq ft roll. It looked pretty thin, had a plastic backing instead of aluminum, and din't feel all that sticky so I opted for some eDead v1se(70 mil) for about $1.50 sq ft shipped(with discount).
The back definitely wasn't gritty. You sure you got the right stuff Nick?
-Fishy
Username: Hellbender
Los Angeles, California USA
Post Number: 38
I found some stuff at home depot called "stormguard" . It had a plastic backing and while it looked kinda thick it wasnt very sticky or flexible. They also had somethign that came in a roll that was 12" x 35' ,I think it was called weather or water shield. That was very flexible and sticky but the label said it was only 25mills thick. I dont remember the price on that stuff.
Username: Goon
Post Number: 140
lowes also has the peal and seal stuff. i've heard it works just the same.
goon
Username: Thumper
Richmond, VA U.S.A
Post Number: 49
i believe the off brand dynamat has tar based elements in it so, using that would make your car smell like a freshly paved road. Dynamat uses butyl and aluminum, very flippin expensive. works great near firewall but i wouldnt spend that much money for the trunk and doors
Post Number: 41
This is the stuff at home depot near me.Its called stormguard. It withstands high temps and is a butyl based underlayment. 200 sq ft roll for $67 . http://www.gaf.com/General/GafMain.asp?Silo=RES1&WS=GAF
Yeah ice and water shield lucky my buddy works for roofing company gimme rolls for free. Its slick on one side sticky on other heat up using dryer works great.
