PolyFill
How do i install polly fill in my ported box? Do u have to glue it down or soemthing
Username: Davids2004
Houston, TX USA
Post Number: 768
Yes use some 3m 90 strength spray adhesive. But watch out some may come flying out. I wouldnt suggest it though. Didn't work well for me.
Username: Minime
Portland, OR
Post Number: 31
I just got some fabric at the place where I got the polyfil. Then I got the staple gun out and stapled down the edges of the fabric and stuffed it with the polyfil.
Username: Fordpwr
Los angeles, CA Usa
Post Number: 172
depends what kind polyfill you are gonna be using.If you are using the loose kind then you can staple a piece of wire mesh inside of the box where the port begins, if it's the "roll" type (wal-mart) then thats easier , just staple it with a wood staple gun.
