My cd player doesn't work with my lights on at night! help!
Username: Fufu182
My cd player doesn't work with my lights on at night, any suggestions on fixing this problem? I don't see how it could be affected since we used the same wires the radio had before. Please I need suggestions.
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 1987
you used the car's ilumination wire for the ground.
just a bad wiring job.
what's the make/model.year of the car
I'll look up the color codes.
Jack E. Jett
When I installed a Durabrand CD Changer in my 97 Saturn, my back lights & dash lights don't work. I used the FM modulator. Let me know what I'm doing wrong, please. Thanks.
oz
hey i have a cd player that wont take any cds
it was fine like yesterday but i dono what happend. also the cd player is like brand new sooo i dono. if any of u know what the problem could be that would help thx
Durabrand....lol...cappy cd players that wal*mart sells. Waste of money I have to say.
Username: Spittin2rock
Post Number: 88
Jack when you installed the cd player it might have blew the fuse. It should be one fuse that controls your dashlights, and rear lights. Find the fuse and see if it's blown
