400 bucks
Username: Mr_kebo
Albertville, Al USA
Post Number: 173
My Buddy is comming how from MOS school in texas for the Marines. Well he has an amp its a kenwood KAC-X811D. And he needs a sub. He said he wanted to spend like 400 on the sub and box together. What do yall recommend. He said he wants it to be loud and sound good ;) Btw if this will make it easier.
POWER RATINGS (CEA-2006 STANDARD)
-Dynamic Power: 566 Watts
-Output Regulation: Under 0.2dB (4 ohms)
-R.M.S. Power Output (1-Ohm/1-Channel): 1016 Watts (1.0% THD+N)
-R.M.S. Power Output (2-Ohms/1-Channel): 919 Watts (1.0% THD+N)
-R.M.S. Power Output (4-Ohms/1-Channel): 533 Watts (1.0% THD+N)
-Signal-to-Noise Ratio: 74dB (4 ohms)
-Signal-to-Noise Ratio (Bypass): 74dB (4 ohms)
15" RE SX - 1000w RMS and it's dual 2 ohm, wire it in parallel for a 1 ohm load. it's only $280 dollars shipped to your door. Great, great, great sub. www.reaudio.com
Box, build one. If not. well other people on here could recommend places better than I could.
Username: 54danny54
Post Number: 128
try:
image dynamics:idmax, u can hook up a few them watts lol
jl audio:a couple w6v two or w7
Username: Taylor17
Kopperl, Texas
Post Number: 1262
Eclipse Ti, is another good sub...
