Bronze Member Username: Chris_ballerMidland, Ontario Canada Post Number: 38 Registered: Jun-04 | I'm looking to spend about $250 for an amp and and hoping to replace my 2 12" legacy subs cause they're not the greatest. Only looking to spend about $150 but want good quality sound What are everybody's fav. subs and amp |
Silver Member Username: Jwbulger79Florida Post Number: 382 Registered: Nov-04 | here's a list of some good brands. for $150 i would get an Atlas 12 from www.ascendantaudio.com, but here's some other good options. for $250 you should be able to get a good amp. look for one that puts out 250 to 350 watts RMS @ 4ohms. personally, i would run it with a precision power (ppi) art series A300 amp or the PC2300. you'll have to find one on ebay b/c they dont make them anymore, but they are some of the best amps ever made. |
Anonymous | 2 kicker comp vr 10s ($135) or 12s ($165)(not the new 2005 ones) depending on what you're willing to spend are both great subs for the money. MTX are very good amps are in you're range ( 421D-420w rms is $165 and 801D-800w rms is $255) I found the prices at cardomain.com |
Silver Member Username: Jwbulger79Florida Post Number: 388 Registered: Nov-04 | MTX makes great amps for the price. very reliable. |
