Posted on so would it be smarter to get two l5 inch l5s or two 12 inch l7s? and theoretically i could use the same amp on either of those systems correct? and just a sidenote, what kind of amp would you have to use for a kicker solox 18incher, examples would be appreciated |
Gold Member Username: Subfanatic
Walton,
Ky
Post Number: 1846 Registered: Dec-04
Posted on id go for the 12 inch l7's more surface area, but for the solox you can add more than one amp i believe, and i would run US amps |
Posted on wouldnt the 15s have more surface area? maybe i misunderstood you |
Gold Member Username: Invain
Michigan
United States
Post Number: 1870 Registered: Aug-04
Posted on Yeah, not sure what sub's thinkin'. Two 15's will have more surface area than two 12's. |
