2 subs each 4 ohms can i run a mono amp 550 rms at 4 ohms? This amp will give 1100 watts at 2 ohms. I'm guessing it will give 550 watts for each sub right? Is this dangerous for the subs if they can each handle 550 watts rms? this amp is Hifonics BX1605D for audiobahn 550 watt rms flame excursion subs. Thx
you should be fine....if they are SVC 4 ohm subs you can run them at a 2 ohm load...if they are DVC you'll be running at a 4 ohm load....as for the subs...chances are with there RMS rating they wont last long...audiobahn isnt exactly known for there true ratings
oh my lordy... "you should be fine....if they are SVC 4 ohm subs you can run them at a 2 ohm load..." if they are svc 4ohm subs all you can run them at is 4ohm.. man that just sounded stupid. you dont pick what load your amp gives out YOUR AMP HAS NOTHING TO DO WITH THE OHM LOAD the amp sees it from the subs and runs at that load retart.
