Anyone have plans for a bandpass box
Username: Red_devil127
Cumberland, Wisconsin Us
im lookin for a good plan for a bandpass box for my 2 12" folfenhag. they are 500w RMS 1000 watts total dual voice coil. the box needs to sound really good. the box is goin in my room... im also lookin for a good neon light setup for the box so anything that can do to help is awsome. email me or give me a call 1715-671-3048
nick_sq
bandpass went out with the 90's,lol. Ported box with plexi viewing window would be better...
Dat dude
illll bandpass
na im juss playin im into sq
ok then do you have plans for a ported box with plexi viewin??
Username: Redskin
LondonEngland
Post Number: 130
So what does a plexi window add then?
Magnet: 160 oz. Double stacked Ferrite magnets
Frame: 5 spoke Die-cast aluminum basket
Cone: Reinforced aluminum curvilinear
Surround: Oversized buytl rubber
Spider: 2 Flat ultra excursion
Power handling: 500 watts RMS, 1,000 Watts Program (conservative)
T Yoke: Industrial Chromed Hex bolt retained, Bumped and Vented
Double damper magnetic motor assembly
Cooling: Double Vented (T Yoke and Motor Side vents)
Voice Coils: 4 Layer Dual 4 Ohm High Temperature black Aluminum
Voice Coil Diameter: 2.2"
Nominal impedance: 4 ohms / per coil
DC resistance (Re): 3.2 ohms each coil
Frequency range: 20 Hz-1.1 kHz
Fs:30 Hz
QTS:.526
QES:.614
QMS:7.698
VAS:56L
SD:.0491M
SPL:90 dB 1W/1m
Xmax:16mm
Mounting Depth: 165 MM
Mounting Hole Dia.:296 MM
That is the specs for my volfenhag subs.... see what you can come up with for a box
Username: Fishy
Tamarac Ft.Laud, FL USA
Post Number: 803
I wouldn't go by any "stock" suggestions. Car and home are two very different enviroments and usually call for different subwoofer allignments. This is one place where WinISD might give you good results.
What do you plan on powering these things with(please don't say a car amp)?
-Fishy
i dont have to put any thing on them for an amp because i have an aduio video reciver that puts out way more than enough power to push the subs. so no i am not useing a car amp.. i have another question for everyone here though. does anyone have an idea for a good setup on neon lights for the box too.. i have a bandpass box already that has a string of neon but i need another box and i want a better setup for neon
