Clifford '94 remote trashed...need aftermarket remote
I;ve got a '94 Ford E350 with a clifford alarm, model unknown. The remote is pretty beaten up, and after the latest round of sottering the battery 'holders' on, the unit is done.
The remote has a few numbers, but I do not know what model it is, nor do I know where the brain is...what should I look for?
Username: Jeremyc
OK in less t... South Korea
Post Number: 625
Look up under the dash and you will se a black box about 3.5 inches by 5 inches. Pull down till you can see anything writen on it. It should say something in big black raised letters. Write down what you see, and call your locale clifford dealer. They will know what remote to order to get it working.
While you are at it check out the clifford website and download the manual for your alarm using the model you found on the brain.
