The twoLoudest SPL
I have a hifonics BX1500d which produces 1500@1ohm and 1000@2ohm. Im looking for either one 12 or two 12s, i want to spend 250 or less. I just want the SPL i dont care about SQ.
also id rather not buy from ebay.
Username: Steelheadgoof
Fairfield, California US
Post Number: 40
Spending 250 or less really restricts you. But for 250, and you only want spl, than two 12 p5 xlpodes would be fine. but they will explode in a few months
Username: Addicted2bass
Miami, FLORIDA USA
Post Number: 453
how bout a few moments. For 250 the only thing im thinking of that would give you te most spl is a kciker L7 dual 4 ohm subwoofer
Username: Rob315
Cuse, NY U.S.
Post Number: 416
if he got the dual 2 ohm 15 he could run that hifonics at 1 ohm and that sub will pound...sound like sh*t, but pound!
Username: Taylor17
Kopperl, Texas
Post Number: 1230
L7's. alpine type X.
Just a few more choices...
Username: Taylor17
Kopperl, Texas
Post Number: 1231
the alpine type X doesnt look bad, do u think i could sent like 1300 watts to that or would that be too much
Username: Taylor17
Kopperl, Texas
Post Number: 1235
I wouldn't really recomend it... I haven't heard minny people talking about putting more power than it is rated for.
It could handle it if you are trying to compete, but not for dayly use.
is Diamond Audio any good? ive never heard of them. Do u think two 12" CM312D4 rated at 500rms each would be louder than a type x?
Username: Taylor17
Kopperl, Texas
Post Number: 1236
Sorry, don't know much about them. There not subs people usually talk about. They don't look half bad though.
Username: Jonathan_f
GA USA
Post Number: 3562
Two Adire Audio Shivas will work well in that price range, and power range. Also look into Ascendant Audio. Anyway, put them in a ported box and pack power on them.
Ok ill look into those. The reason i dontw want to go with kicker is because i already have a ported box for round 12's.
Username: Taylor17
Kopperl, Texas
Post Number: 1237
I totally understand. I want to go with some solobarics, just to see what they sound like... but they won't work with the box I already have!
I was looking at Adire Shivas and they say that there 650 325 to each voice coil, is that rms?
Username: Chenzevy
Post Number: 45
HOW ABOUT AN RE: SE?
OR AN RE: SX?
GA USA
Post Number: 3564
Yep, that's RMS. You generally won't need that much power to get full potential out of them, but in a ported box near the tuned frequency you can pack on power without stressing the mechanical limits of a sub.
GA USA
Post Number: 3565
I'm sure there are some cheapie subs that you likely could get more SPL out of, but chances are you wouldn't want them. Anyway, you could scour ebay for subs if you like, you could get a better used SPL sub for the price of a new sub.
Derk
Go for 2 Pioneer TS-W3004SPL subs. Go to ebay, you could easly snatch 2 of them for under $250.
Username: Subfanatic
Walton, Ky
Post Number: 1798
how about 2 12 inch Rf p3's for 250 lol...from me lol
