Amp setup to an 18" MT
Username: Coolcardude
Or
Post Number: 23
i plan on getting an 18" MT but its going to be a daily driver sub with a possibility of comps if there close. i want to have 4 amps, but is there some way i can have four amps hooked up at all times but only have 2 working untill i flip a switch or something to engage the other two for comps?
Username: Jmloughrey
Farmington, CT
Post Number: 1070
you could have 2 of the amps connected to your head units remote wire and then the other 2 you could have the remote wires connected to a switch...
Username: Loudnobnoxious
Post Number: 128
stop being a bish and use all 4 daily.
What impedance are you looking at in an amplifier?
