JL's H.O. Boxes - any thoughts on these - interested in them
Username: Suleman36
Post Number: 382
Im thinking about running a H.O. box with a sub. I will be using a 500/1 possibly for this setup. Which sub should i put in this box??? How whould it sound?? it says on the website that its a patented ported design and its very loud and maintains good sq/spl.?
Username: Jeremyc
OK in less t... South Korea
Post Number: 590
They are designed to work the Jl sub to the best of its ability. IMO if your going to use a prefab box for a JL sub, thats the way to go.
Username: Suleman36
Post Number: 384
Hey Jeremy i was gonna run a 1000/1 and my 2 13w6v2's but i may hold off until i get a bigger car or HO alternator. For the meantime. I will be running a Eclipse cd8454 for the hu and a 500/1 for a sub or subs and a ppi art 300.2 for my componants in the front. I plan on taking the rearspeakersout for better bass response thru that. Now that we have the foundation...what JL sub whould sound the best in a HO box. It can be either 2 12w3v2's in the H.O. box or a 12W6v2 or a 10w7??? If i missed any you let me know but which whould sound the best with that 500/1? im looking for a sq and alot of spl. I listen to mostly rap and some rock..maybe NIN and electronica..give me some thoughts..thanks
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 132
H.O Box and sub combination is very nice, i wouldn't change the sub out for another brand or model though.
Stockbridge, GA USA
Post Number: 133
i'd go with the 10W7 or if you don't like the way W7's sound (some people don't) then go with the 12W6v2. just because i think they are better subs then the W3's
but for SPL i've heard the W6's aren't very good and obviously the 2 12W3v2's will have more piston area.
MO - you posted after i posted my first message
Username: Jeremyc
Post Number: 591
Go with the 12 w6v2. Its a great sub, and will be right in route with the additions you want later. If you start getting into the W7 line I would go with the 12 and use your 500/1 on it for now. With the HO box the 500/1 will be plenty.
Username: Suleman36
Post Number: 389
Do you think a 12w7 whould work with a 500/1 jl amp in a H.O. Box by JL that it comes in. Or should i stick with the 10w7. The 500/1 is underated.
Stockbridge, GA USA
Post Number: 137
if you plan on upgrading the 500/1 to a 1000/1 or simular amp later with the 12W7, you should be fine starting off with a 500/1
Username: Suleman36
Post Number: 391
Brandon..how much of a differance will i hear from the 500/1 to the 1000/1 going to the 12W7 sub in that H.O. Wedge Box thats ported.
Username: Suleman36
Post Number: 397
Jeremy i think ill demo both at the dealer and go from there. thanks for your info and thanks to everyone else
Stockbridge, GA USA
Post Number: 139
that'll be best, hear it for yourself, lol
oh and why so many threads going on MO?? just replied to another one in the AMP section
Username: Nitescort
Post Number: 29
gotta have MO threads! LOL
Username: Suleman36
Post Number: 398
lol
thefirm0
i need help choosing sub for a harley davidson supercrew f150. it has the pilot seats so i have a gap between the rear seats. Any suggestion of what size subs i should put in and what size amp to keep them hitting hard as f****.
Username: Suleman36
Post Number: 433
Get 2 10W7's run off a JL 1000/1 and it will hit very hard and give you more then you expect. Just make sure you have the right box for it and get a good install.
Username: Fishy
Tamarac Ft.Laud, FL USA
Post Number: 790
If you got the cash:
http://www.jlaudio.com/stealthbox/f150_CTR4.html
-Fishy
