Q-logic kick panels
Username: Jbailey
Indianapolis, Indiana
I am thinking about installing my components in the kick panels of my car and would like to know if the Q-logic (Q-form) vehicle specific kick panels are any good? I've heard some people say they are good and others say they can be good with a little help. If you are of that opinion, what can be done with them to make them adequate? Thanks
Username: Jeremyc
OK in less t... South Korea
Post Number: 615
They are ok, but I wouldn't use them unless I beefed it up on the inside with some fiberglass. From what I hear they are alot better if you do.
Username: Point78
El cajon, Ca
Post Number: 29
i have had them in my truck for a while and i havent had any prolems with them and they sound fine. the only thhing i dont like is the one on the drivers side if i push my e brake to hard it hits it
