Speakers
Username: Grandam95
Willoughby, Ohio Lake
what is a cheap pair of speakers that would sound allright
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 230
whichever ones you listen to that sound good to you and are cheap
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 145
Well said.. Brett you are going to want to go to an audio store and listem to some speakers(If you want cheap speakers you are probably going to go with coaxials). Whichever set you find to be the best, do a search on some online retailers (which are generally cheaper) and buy them there or ask that audio store to match the price.
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 146
Also, for cheap coaxials I would check out Infinity's or POlks.
