I NEED HELP WITH MY SYSTEM?!?!
Username: Kit
Australia
i have a type r 12" 4 ohm DVC runnin off a M300 not 301!!! M300 (so people dont get confused) because theres like a 50 watt differnce between the 2 amps.
the type r is 300watts rms
so correct me if im wrong too say that i am runnin at 1/2 power because the sub is a 4ohm so its rated in the alpine catalog as 150 x 1 rms @ 4ohm 14.4v
because i was told that i wasnt runnin 1/2 power but i dont see how i am? could someone plz explain this too me cause im new to this
heres a site to see full specs on it BUT it says the rms power output at 4 ohms is 100watt so im confused?!?!
http://www.epinions.com/Alpine_MRD_M300_V12_AccuClass_D_Mono_Amplifier__Mono_Sub woofers_MRD_M300/display_~full_specs
Username: Addicted2bass
Miami, FLORIDA USA
Post Number: 417
NO you are not running that sub at half power. Its a 4ohm DVC sub. Which means you cant wire that sub to a 4 ohm load. You can wire it in a 2 or 8 ohm load. Tell me how dfo you have the sub wire in the box.
Username: Kit
Australia
sorry i forgot to mention its a digital amp not the analog one if that makes any differnce at all
Miami, FLORIDA USA
Post Number: 425
I dont think it does but ow do you have the sub wired in side of the box?
Username: Kit
Australia
sorry but i dont quite get ur question? its just runnin straight from the digital amp which drives the sub at a 2 ohm load
Username: Kit
Australia
im sorry i dont really know because a certified alpine specialist hooked it up
do you mean as in parallel or bridged?
Miami, FLORIDA USA
Post Number: 426
Ok, since you're sub sub is a DVC sub the sub can't be wired at 4 0hm's it can only be wired at 2 ohms or 8 ohms? because in your first post you said the sub was running at 4 ohm's and it cant be. So i was asking how is your sub wired inside of the enlcousure because that would make a difference in the ohm load.
Username: Kit
Australia
ohhh sorry its just in the catalog it said that it is a dvc 4ohm subwoofer sorry cause im just fully dumb at this stuff right now
Username: Kit
Australia
Post Number: 7
so what if both the coils are wired up that means im runnin a 8 ohm load?
Miami, FLORIDA USA
Post Number: 427
http://www.crutchfieldadvisor.com/S-b90IuRkN5N3/learningcenter/car/subwoofers_wi ring.html?subs=1&impedance=DVC4x2
is it wired like the first one or the second one.
Username: Kit
Australia
Post Number: 8
1 sub / Dual Voice Coil - 4 ohms x 2
Option #1
would be the one im pretty sure
Username: Kit
Australia
Post Number: 9
the pic that has (1) 4ohm DVC speaker = 2 ohm load
Option #1
Username: Kit
Australia
Post Number: 10
ill prolly open it up and check it out my brother has told me that they way alpine wired it would be in the subs manual but i dont have the manual and im tryin to look for it its the model swr-1240d
Username: Kit
Australia
Post Number: 11
hey basslova i am runnin at full power ive checked it all out thanks for all you help
Miami, FLORIDA USA
Post Number: 428
oh ok if its option 1 then you'll be fine.
