RE MT amps
Username: Balls573
Winona, Missouri U.S
Post Number: 12
I am gonna buy a Resonant Engineering 15" MT. I want to use Hifonics amps for sure but am not sure what size. I want the sub mostly for comps. Would 2 BX1605Ds be too much or should I use 2 BX1205Ds. I want to put it in a 6 cu. ft. ported box with 2 of either the BX1605Ds or the BX1205ds with a 5 farad Alumapro capacitor and a 200 amp alt. This is all in a 1988 GMC s15 Jimmy. Would that setup be good enough to win comps? The sub will be dual 1.4 ohms with one amp to each VC.
Username: Subfanatic
Walton, Ky
Post Number: 1631
get the QVC 1 ohm sub and run 4 hifonics brutus 1500d amps to it
ThatGuyYouKnow
They made new amps with new names =/
mostly just new names, most sites havnet changed the names.. yet.
Username: Addicted2bass
Miami, FLORIDA USA
Post Number: 436
For comps seen MT's hold up to 10,000watt rms for burps. And with those hifoncis ampsthere rated at 1600 watt rms so if you get 2 that would be 3200watt rms and Around 2000-3000watt rms is recomended for daily driving, so 3200 should'nt hurt a bit.
Walton, Ky
Post Number: 1725
bass, what would you say, run 4 jbl 1200.1 of hifonics brutus 1500d
