Soundstream reference amp question/ opinion
deong
yes i wanted to know is there a difference between the reference 500 and the 500sx and if so which is better and i also wanted to know if the reference 300 is any good for running it a low ohms. thanks
deong
i wanted to know because i was intending to sell my hcca 225
Username: James1115
Wilton, Ct
Post Number: 2006
the reference 500 is an incredible amp. The SX isnt stable as low as the older 500 and not as good quality. The 225 is a very good amp as well they are both stable down to 1/2 ohm stereo but the reference will outpower the 225 if thats what your looking for. I personally love the older soundstream reference model amps USA made vary good quality stuff:-)
