hey guys im buyin subfan's eclipse Al 10 inch 88100DVC and i e-mailed eclipse for enclosure specs but they gave me helpful information but not the dimensions... i was wondering what an experienced person would reccomend for it
and subfanatic .. what were the dimensions of the box you had it it?
and just incase any1 can help with this... i also bought an Eclipse EQ .. the 21010 i really dont know what to tune it to or anything so should i just leave all the knobs in the middle until i get it tuned or would you reccomend certain setting that will sound good on all EQs but obviously wont be perfectly tuned ...
these are the EQ specs
Retractable Knobs for Easy Access to each Fader, Frequency, Level and Q Control and Precise Adjustment Equalization Frequencies: Parametric; 25100Hz Graphic; 250Hz, 600Hz, 1.5kHz, 4kHz, 10kHz NOB Rotary Encoder for Master Level Control and EQ Defeat Function Front Panel A/B Input Selection High-Pass and Low-Pass Filters for Front & Rear Channel and Subwoofer Output Adjustable 0 to 4 sec. turn on delay Input Level Control Gold-Plated RCA Jacks FR-4 (Military-Spec) Anti-Vibration Circuit Boards
okay thats it for now lol... i appreciate all the help fomr you guys on ecoustics
Trevor they gave you recomended enclosure sizes.. maybe not dimensions but i dont think most companies tell you that specific.
1.5cf or any of the other sizes i am sure could be built in more than one way. Are you buying or building? Since sealed seems to be what they want for this sub you got some headroom for error if the cf is not perfect.
Which one are you wanting to use .45? .75? 1.25? or 1.5? I can throw out some dimensions that fit that..
im trying to decide because i want loudness but i want to really get the great SQ of eclipse subs... so i was thinking of maybe .75 or 1.25... if i made a 1 cuft box would it go between the two or do they not have that listed becuase it didnt produce a good outcome? and also... since its only 1 ten i was hoping to be able to leave the third row seats up and build the box fiting to the back of the seat and have the sub pointing upward to bounce off the glass and into the cabin... the car is an escalade by the way ... here i;ll draw an idea on paint real quick to show you..
with that setup and having a third row seat, firing at the rear glass would probably give you the best results out of any with 1 10".
as far as going between the .75 and 1.25 with 1.0cf i dont see a problem with it. The specs they stated are probably were they saw peak performance/sound for each type of bass. You really cannot go wrong with a sealed enclosure with specs that are within reconmended range.
Trevor, not really sure the deminsions i could give ya, and i wouldnt reccomend my box, its too small i would go much bigger and its like 1.3 i think, i would go like 1.5-2.0 if you could, but are you going for the full out sq this sub can give you, cause its sooo amazing, i hate im giving it to you lol
