Mtx 1501d i channels 1500 rms
Username: Cesar147
Mcallen tx, Tx Usa
Post Number: 13
i just buy this amp on ebay , so i need to know if this amp is good what do u think about this amp thanks
Username: Marley289
Post Number: 150
i would think it is a pretty good amp. i have the mtx 421d, and i couldnt complain, its loud and makes my subs pound.
Username: Byrumjr
Post Number: 146
That amp is ok if you want to go deaf. I have been wanting that amp for a while now. With the right subs and box that amp will give you want your looking for. It will do more than it rated. Just a guess around 1756 rms at 2ohms. Some places say use 4 gauge wire but I think you need 2 gauge wire for that. It has 150 amp fuse and will pull around 100 -130 amps from the battery.
