New member Username: Adriand619San diego, Ca U.s Post Number: 3 Registered: Feb-05 | Hey guys,Can a sub like the 10w7 get as deep as 12 or 15 inch sub. Because every car audio man tells me that 10 inch subs are more for jazz and pop listeners and bigger subs are more for rap.I listen to rap and r@b more.Can the jl 10w7 achieve the same amount deepness of a 12inch and 15inch sub. |
Bronze Member Username: SwantlaphoenixTucson, AZ Post Number: 62 Registered: Oct-04 | No It Cant. THe bigger the sub the lower the frequency it can play. |
Gold Member Username: Jonathan_fGA USA Post Number: 3544 Registered: May-04 | If you put it in a ported box and tune it low, it will sound as deep or deeper than a 12" or 13" sealed because it is so authoritative. Other than that, apples to apples, the 12W7 and 13W7 will get a little deeper than the 10W7. |
Silver Member Username: Suleman36Post Number: 400 Registered: Feb-05 | Hey i just ordered a 10w7 in a H.O. Wedge ported jl box and will run it off the jl 500/1 amp. I really wanted to go with the 12w7 but with the 500/1 the 10w7 i will get the most out of that sub setup. am i right? |
Gold Member Username: Jonathan_fGA USA Post Number: 3546 Registered: May-04 | The 500/1 is a good match for the 10W7 or the 12W7. You'll push the 10W7 to it's potential more easily with the 500/1, but the 12W7 will get louder with the same amp and still perform very well with the amp. |
Silver Member Username: Suleman36Post Number: 402 Registered: Feb-05 | So what is the best way to go you think at the end? Overall i listen to mostly rap. But i want the most out of this setup. 10w7 and 500/1 or 12w7 and 500/1??? lol |
Gold Member Username: Jonathan_fGA USA Post Number: 3547 Registered: May-04 | I'd do the 12W7 and 500/1 if it were me personally. Up to you, though, neither will disappoint you. |
Silver Member Username: Suleman36Post Number: 403 Registered: Feb-05 | How much is the differance i will notice???? what kinda differance. you say itll be deeper but will it be noticable? The guy at the shop said that the 12w7 sounded alot better with the 1000/1 cause they had a customer with mysetup upgrade to a 1000/1 with a 12w7 from a 500/1. |
Gold Member Username: Jonathan_fGA USA Post Number: 3548 Registered: May-04 | The 1000/1 wakes it up a little bit, but it will still perform well with the 500/1. Just my personal preference as far as 12" over 10", you'll notice a bit more depth and punch with the 12", but it's not drastic. SPL of the 12" is higher. |
Silver Member Username: Suleman36Post Number: 405 Registered: Feb-05 | I think ill stay with the 10W7 cause its not gonna make a major differance. I think this 10W7 in that H.O. Wedge Box will be very loud and clear and more boomy then my 2 12w6v2's i currenty own and alot nicer to my electrical system. |
