4 ohm/ 2 ohm/ 1 ohm wiring????
dave21
how would u wire a 4 ohm dvc sub down to 1 ohm.
same thing with a 2 ohm dvc sub.
is it possible???
Username: James1115
Wilton, Ct
Post Number: 2084
www.jlaudio.com then go to tutorials, then to wiring diagrams. it will show you how you can wire different sub/subs vc configurations down to different impedance's in parellel/series.
Username: Addicted2bass
Miami, FLORIDA USA
Post Number: 460
its possilbe to wire a 2 ohm dvc down to 1 ohm in parrelel. But a 4 ohm dvc sub you can only wire it to a 2 or 8 ohm load. Unless you buy two.
