Ed nine.1
Username: Rob_brown
Post Number: 195
If my amps input sensitivity is 1.5mv-7v and my headunit puts out 6.5, it's a pioneer premiere, so it really does, does that mean i should turn the gain almost all the way up or does thathave nothing to do with the gain? Thanks
Username: Jeremyc
OK in less t... South Korea
Post Number: 570
You match the gain with the out put on your amp. Since the Output is that high your gain should stay pretty low.
Keep in mind when you turn up the gain, your turning up the (SENCITIVITY). So your making the amp work harder looking for the signal, and that leads to distortion. Thats not a perfect example of what happens, but its an easy way to understand the coralation between gain and line out voltage.
Username: Rob_brown
Post Number: 198
what's the output of my amp? i'm not really sure what that is, just that the variable input sensitivity is 150mv-7v
Username: Rob_brown
Post Number: 199
oh, my HU puts out 6.5 volts
Username: Jeremyc
Post Number: 571
The output on your amp doesn't change with the line out voltage on your deck, or the gain setting. Look on ED's web site and they will have the rms output of your amp listed.
Username: Rob_brown
Post Number: 200
oh, in watts? it puts out 1200 rms at 1 ohm, that's what i'm running it at.
Username: Rob_brown
Post Number: 201
it's powering a 15" X.X.X
Username: Rob_brown
Post Number: 203
anyone?
