3 12w3v2
mikey805
need amp for 3 12w3v2's, can get a rf t10001bd for 450 bucks new, would that be a decent setup?
Username: Lilbuck12
I would definitely recommend the RF Amp but you should definitely get at least two amps to power all three subs.
mikey805
the amp is rated @ 750 watts at 2 ohms and 1000 @ 1 ohm, the subs i believe rms @ 250- 300 watts
Username: Lilbuck12
Post Number: 7
well i guess if you run it at 1 ohm you would be alright. I would still recommend runnin two amps.
Username: Addicted2bass
Miami, FLORIDA USA
Post Number: 324
naw i tihnk he would be okay with just the 1 RF amp
Username: James1115
Wilton, Ct
Post Number: 1986
yeah I second what bass is saying. that amp would run them fine.
Username: Suleman36
Post Number: 359
Hey you think a jl 500/1 is a good match for 2 12w3v2's???
Username: James1115
Wilton, Ct
Post Number: 1992
yes
htrpr
yes thats perfect.
Username: Taylor17
Kopperl, Texas
Post Number: 1151
Yes on the JL 500/1, and a big yes on the RF amp.
