Best JL subwoofer for good SQ and Great SPL???
Username: Suleman36
Post Number: 340
Im trying to find either 1 JL sub or 2 subs that will sound great with a 1000/1 jl amp. Im looking for good sq and great spl. I was thinking about going slot ported. What should i run of the 1000/1??? so many choices like 2 10W7's or 2 13w6v2's or 1 12w7 or 1 13w7
Shab
13 w7
Username: Shab
Tampa, FL
I would get 2 10" w7's if you want sound quality
Username: Subfanatic
Walton, Ky
Post Number: 1418
i would go with 2 12w6v2's with a single 1000/1
Username: James1115
Wilton, Ct
Post Number: 1967
13w6v2's . thats what I would do. Hey MO dont you already have them?
Username: Suleman36
Post Number: 341
Yeah i use to run 2 12w6v2's off a ppi pcx 2200. Now i am gonna get a 1000/1 and trade in my 12w6v2's for another set. I want most out of the 1000/1. I want more spl and somthing that will work well with my front componants. Its gonna be either sealed or ported by the way. WHich one yall.
Username: James1115
Wilton, Ct
Post Number: 1969
13w6v2's
Username: Suleman36
Post Number: 344
Hey James..Myer Emco has this upgrade policy for up to a year if you go with somthing bigger. So i keep testing all the jl subs..lol What do you think i should stick with? So far the 12w6v2's were the best sq wise in a sealed box it came in. Ive never heard them in the slot ported box jl recommends cause i bought it sealed. They have the 13w6v2's in stock and i can upgrade if i want. What do you think is the best choice for the 1000/1 and what kinda box man?
Username: James1115
Wilton, Ct
Post Number: 1971
I would do the 13's slot ported you will be very happy with the way they sound especially if you liked the 12's sealed.
