Kicker or alpine?
the alpine type-E swe 1241 two 12" or the kicker comp 03c124 two 12" there bolth same price but which would have more SLP and SQ. they will be powered by a MTX audio thunder 421d amp 210 rms@ 4ohm, 420 peak.
Username: Taylor17
Kopperl, Texas
Post Number: 922
The Alpine is there bottom line sub, so I think the Kicker is the better option. The Kicker isn't that bad of a sub for the price. I was actually suprised at the sound of them.
Username: Djshyper
Dalmeny, Saskatchewan Canada
id go with the alpine but it is the low end of the alpine chain but is still very good quality but yeah id go with them in my opinion
Username: Nnnnick_b
Nc Usa
Post Number: 254
I agree with Andy. The type has greater excursion capabilities then the comp.
type e - 11.7 mm one way
comp - 7.5 mm one way
The alpine would probaly win in sq as well.
But personaly i would look at infinities reference line as well. IMO they sound better then the alpines and are equally as loud.
Username: Alpineuser
Post Number: 74
are there money issues or do u just want type E? If u can spend a little more move up to a type R much better sub.
Username: Taylor17
Kopperl, Texas
Post Number: 1039
Yep, the R's are much better.
Username: Kenwa
Post Number: 79
Go with the kicker for sure, and if you can spend a little more dont get the type R get the kicker comp VR
Post Number: 93
lmao comp vr over type r?
Post Number: 94
Username: Wojopro
Silverdale, WA
Post Number: 210
Agree with AlpineThumping on that.
