Capacitors...question..
Username: Jbaker97
Houston, Tx Usa
Post Number: 20
If you are using a capacitor why would you need a bigger alternator. Isnt that the purpose of a cap. so your amps dont draw from your alt.
Username: Sancho886
El Cajon, CA US
Post Number: 103
where do you think the cap draws from?
Username: Jbaker97
Houston, Tx Usa
Post Number: 21
But dont they draw really slowly to keep from frying the alt.
Username: Sancho886
El Cajon, CA US
Post Number: 104
http://www.wickedcases.com/caraudio/capacitors.html
Username: Jbaker97
Houston, Tx Usa
Post Number: 22
Do you think that running two RF 800.2 would fry an alt. Its not really that much power.
Username: Taylor17
Kopperl, Texas
Post Number: 1068
It will eventually kill it. I'm running just 1 RF P8002, and a RF P4004 and my lights dimn like a mofo.:-) If I had 2 P8002's my alt wouldn't be able to handle it for verry long.
I would recomend getting an HO alt.
Username: Importrapist
Savannah, GA U.S.A
Post Number: 47
I run almost the same setup as Taylor, and my car is DYING!!! I just went out and bought a new HO alt (200 ampres) for $188, they arnt that expensive if you know where they are. Ohh yeah, i run a Stinger 1 farad cap, and it dont do squat!!!! just to prove i know what im sayin..
Username: Taylor17
Kopperl, Texas
Post Number: 1096
How much has the new alt helped?
Username: Suleman36
Post Number: 336
HEy Darren where did you get your HO alternator? for that much
