Can the 16 mc1300d push the 12w7. glasswolf help...
Username: Onthelow
Ft drum, Ny Us
i bought the memphis belle amp, on the channel 5 it puts out 1100w rms at 1 ohm. I have a 12w7 which i plan on upgrading to the 13w7 which is dvc at 1.5 ohm, but if i save the $ that alright by me. the 12w7 is svc at 3ohms only will it still work?
Username: Its_bacon12
Post Number: 255
well, unless you plan to run a 13w7 in paralell to .75 ohm, yes the 12w7 will work
Username: Onthelow
Ft drum, Ny Us
Post Number: 7
thanks bacon, i'll try the 12w7.
Username: N2audio
Lawrence, Ks USA
Post Number: 18
With a 1 ohm amp you're probably better off with the 12 anyway. The dvc 1.5's on the 13 almost force you to buy the 1000/1. Their marketing dept. outdid themselves with that little trick.
With a 1100w at 1 ohm amp you'd probably only get 600 or 700 at 3 ohms and running it at .75 COULD give you thermal problems.
Username: Onthelow
Ft drum, Ny Us
Post Number: 8
Optidriven thanks 4 your post, this is where Im completely lost. Are you saying that in the long run the 1 ohm amp could hurt the 12.
