How would you wire 2 dual 6 ohm subs?
Username: Kenwa
Post Number: 76
The subs are MA audio and they are rated at 500 watts RMS. So what i need to know is how i would wire these subs for a lower ohm load, i think they wire to 1.5 ohms. I also need the cheapest decent amp possible to run them with.
Username: Solacedagony
New Jersey US
Post Number: 317
You'd wire them parallel/parallel to get it to a 1.5 ohm load. I would just get their matching amp from MA Audio since you already have their subs.
Username: Kenwa
Post Number: 80
The subs arent new models so the MA audio amp wont work, so i need an amp that will work, and the cheaper the better just as long as its not junk
