Dual 4 ohms to dual 2?
Username: Sony224422
Deep River, CT US
Post Number: 98
is it possible to wire a dual 4 ohm to dual 2 and then put it in a box with a dual 2 ohm and run them off a mono amp with one channel.
I want to run a dual 4 ohm and dual 2 ohm alpine r's together off a mtx thunder801d, which is 800 rms x 1 at 2 ohms. Would this work?
Username: Bigdanman
The OC, CA USA
http://www.bcae1.com/
figure it out your self.
or the12volt.com
bot of those have ohm calculation helpers.
im too confused from your post to figure it out for you.
good luck.
You can get it to work,but not properly.
Dual 4 goes to 2 or 8(so 2 in this case)
Dual 2 goes to 1 or 4
Anything wiring will not result in equal powering, making problems with cancellation, etc.
