Actually porting a box
Username: Shackashacka
Post Number: 16
Okay, i'm getting ready to build my box for a V-Max 12"...
i wanna port it though
how do i actually incorporate the port? whats it made out of? etc...
any info, websites, etc to help me out would be great
secondly...wats better in ur guy's opinions..slotted ports or round ones?
Username: Nnnnick_b
Nc Usa
Post Number: 263
http://www.carstereo.com/help/Articles.cfm?id=31
http://www.clubknowledge.com/Car_Audio_FAQ/?t16
Those web sites should be helpful
If your are making a square port, then u can make it out of mdf,
if you are making a round port u can use pvc pipe.
Use the manufacturer's recomended size for a ported box.
Username: Alpineuser
Post Number: 76
call the manufacturer they will tell u what they recommend for your setup
chvyzl1
you should check out winisd... if you got the thiele/small specs for the sub. it'll compute port length based on diameter of the port, desired FS response, box size and the subs specs...
Post Number: 17
Okay, i downloaded WinISD...but they don't have the V-Max as one of the choices for their subwoofers
wat should i do? or does anyone know the specs for it?
Username: Chvyzl1
LA, CA
you can input your own sub, but your right, you have to have the specs... try google'in it and maybe you can find some specs... i'll see if i can find any... if you can't find any, i'd just call cerwin vega and give them any kind of serial nuber you can find... manufacturers always have the specs of there products even if it takes 3 people that dont know what they are talkin about and then finally a technician... lol good luck, i'll see what i can find
Username: Chvyzl1
LA, CA
Post Number: 7
o ya, check out www.thielesmall.com it's a huge database...
Blair
where do u download WinISD from?
Username: Chvyzl1
LA, CA
Post Number: 8
go to http://www.linearteam.dk/default.aspx , it's a great program. i dont know why more ppl dont use it.
Username: Chvyzl1
LA, CA
Post Number: 9
hey john, i went through some things and found that a 2 cubic foot box tuned to 30hz (port would be 4in dia. by 15in long) would give you a good sound curve... no gain loss until 40hz and pretty respectable down to 28hz (only a -5db loss). about 90db at 20hz 1 meter away at 1 watt of power. these are pretty good subs and im thinking i might just have to get one. might go for a 15 tho. lol
Post Number: 18
Yeah, i've heard good things about em, so i'm gonna check em out
hopefully they'll work out for me as nicely as for others
the magnet size is okay, low RMS rating comparable to others, great X-Max, and they still sound awesome
Post Number: 19
Chvyz...wat specs did you use to model it on WinISD? I've been looking around and haven't found that many specs for it. Not even CV's website has the specs.
Username: Chvyzl1
LA, CA
Post Number: 11
i just put together some specs... took specs from some of cerwin vega's other subs and from that got a good estimate of how it would run... not exact, but close enough
Qts: .35
Qms: 4.29
Qes: .39
Vas: 80.5 liters
F_s: 25
SPL: 96
Pe: 600
Xmax: 19 mm
btw just bought one... getting here in 3 days, box building time :-)
Username: Chvyzl1
LA, CA
Post Number: 12
i might just call em and try to get the specs... someone has to have them
