Picking The Right 15". Whats your take?
Username: Swantlaphoenix
Tucson, AZ
Post Number: 51
So I was planning on getting the brahma 15" but I'm hearing that they are hard to get ahold of now and they stoped producing them. Now my immediate second thought was the X.X.X. Also... All the setups and vides I see these babies r ported. I have a jeep wrangler with little room. Are they going to sound alright sealed or what? BTW b 4 it comes up.. I'm looking for SQL I guess. I dont want anything that has bad SQ thats for sure.
Username: Nnnnick_b
Nc Usa
Post Number: 280
The RE XX.X is an eccellent sql sub. It will sound great in a sealed enclosure.
Username: Jwbulger79
Florida
Post Number: 287
you may want to look at the avalanche also. they are designed to work well is small sealed enclosures. same motor as the brahma and x.x.x
http://www.ascendantaudio.com/Avalanche%2015.htm
Username: Invain
Michigan United States
Post Number: 1773
Yeah, you should look into the Avalanche if you don't want ported. Supposedly a great sql sub, I'm getting a 15" my self actually. They work perfect in sealed boxes anywhere from 2 - 2.5 cf.
