Silver Member Username: Sony224422Deep River, CT US Post Number: 102 Registered: Dec-04 | if i have dual 4 ohm subs, can i wire them to 2 ohms and then run them off a single channel amp at 2 ohms so i get better wattage? Or is that not safe, and i should just get the dual 2 ohms? |
Silver Member Username: CoryCanada Post Number: 162 Registered: Jan-05 | yes you can wire two 4ohm speakers into a 2ohm load(by wiring them in parallel) you would get more watts out of your amp from a 2hom load then a 4ohm load(EX:100watts into 4ohms/200watts into 2ohms). But make sure the amp is 2ohm stable. If you got the two subs rated at 2ohms you would need to check the stabillity of the amp at 1ohm or you could wire it into a 4ohm load. |
Silver Member Username: Sony224422Deep River, CT US Post Number: 103 Registered: Dec-04 | ok well my idea is to get the alpine r's. They come in dual 4 and dual 2. I have an amp that puts out 800 watts rms x 1 at 2 ohms. Which ohm should i get? |
Gold Member Username: InvainMichigan United States Post Number: 1803 Registered: Aug-04 | Eric, do you have two subs? You said "sub's", plural, so I'm assuming you have (2) DVC 4 ohm subs. If you do then Cory, your wrong man. Two 4 ohm dvc subs can only be wired to 1 ohm or 4 ohms. |
Silver Member Username: CoryCanada Post Number: 169 Registered: Jan-05 | yeah Joe your right. good thing i have you over look my posts...lol |
Silver Member Username: Sony224422Deep River, CT US Post Number: 104 Registered: Dec-04 | yeah im planning on getting two 12's. I think im just going to get two dual 2 ohm subs so i don't have to worry about anything. There alpine r's.. Mmm |
Bronze Member Username: 54danny54Post Number: 58 Registered: Nov-04 | lol i know i should be in amps askin this but wat amp is 2000 watts at 1 ohm stable lol |
Gold Member Username: SubfanaticWalton, Ky Post Number: 1247 Registered: Dec-04 | http://www.woofersetc.com/product.asp?0=451&1=452&3=3233 |
