Best amp for a pair of boston pros under 300$??
Username: Armadalegq2000
Post Number: 33
let me know would like to go 4 channel but would consider going 2....if 4, would put front two chanels at 125x2 @ 3ohm and rear at 50x2...please advise , was thinking kicker kx850.4 is that 3 ohm stable? can i run my front channels at 3 ohm and rear at 4ohm
Username: Jwbulger79
Florida
Post Number: 267
this amp would make those comps scream:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=39735%26item%3D5760872729 %26
look for an amp that does 2x100 @ 4ohms.
for the rear speakers, you may want to consider just powering those with the headunit or find a cheaper two channel amp that does 50x2 @ 4ohms. check out this article...http://www.caraudiocentral.net/forums/showthread.php?t=33
those are some awesome components, though. so dont
skimp on the amp for those. your rear speakers dont need as nice of an amp since they will only be handling a limited power range.
