Wiring a DVC?
I've got a JL w6v2 which is a 4 ohm DVC rated at 400w rms max and an MTX 801 rated at 400w rms at 4ohm...how can i wire it so that 400w rms is runnin to it?
Username: Addicted2bass
Miami, FLORIDA USA
Post Number: 264
you cant wire that sub to get a 4 ohm load because it a dvc sub. You can wire it only to a 2 or 8 ohm load
Username: Nnnnick_b
Nc Usa
Post Number: 243
you can't. You can wire in parallel or series.
Parallel will result in a 2 ohms load, and series will result in a 8 ohms load.
Did u mean the mtx 8001? That amp is 2 ohm stable, it will deliver 800 watts at 2 ohms.
To wire in parallel connect both positive voice coil leads to the positive on the amp. An likewise for the negatives. (but only if the amp is 2 ohm stable!!!)
so basically...i'll be runnin too much or not enough power with that amp?
Username: Nnnnick_b
Nc Usa
Post Number: 246
Well first, is it 2 ohm stable.
If it is wire it like i said and just dont turn it up all the way. Set the gains so the amp doesnt over power the sub.
its 2 ohm stable...is it worth the risk or should i just get a smaller amp that runs 400w at 2 ohms?
Username: Nnnnick_b
Nc Usa
Post Number: 248
If u set the gains right you shouldnt have ne thing to worry about. If you are worried then u might consider swapping for a different amp, or buy another w6.
i think i might go w/ the smaller amp...i dont want to mess anything up...400 watts rms extra is a lot
