Silver Member Username: Jwbulger79Florida Post Number: 262 Registered: Nov-04 | I have 4ga running from my battery to my 400 watt amp. I want to add a 750 watt power inverter. I wont ever run them both at the same time b/c alternator wouldnt handle it. I've been looking for a dist block that has 4ga in and 4ga out, but no luck. All i can find is 4ga in and 8ga out or 1/0ga in and 4ga out. Can i fit 4ga into 1/0ga inputs? is there any adapter part for that? thanks for the help. |
Silver Member Username: Jwbulger79Florida Post Number: 263 Registered: Nov-04 | nevermind. i found one. http://www.cardomain.com/item/STISTEE4 thanks anyways |
