How to wire 3 subs into 1 box
Username: Mrrogers
Marshall, Illinois Usa
Post Number: 42
i have 3 12's and i need to know the best way to wire them into my box the box isnt divided.
Username: Beetleboyz2005
Post Number: 10
are they single or dual voice coil?
Username: Mrrogers
Post Number: 43
dual
Username: Mrrogers
Post Number: 44
i think heck i dont know how do you tell!!!
Username: Mrrogers
Post Number: 46
hello is anyone there. i need help.
Username: Nnnnick_b
Nc Usa
Post Number: 219
on the subwoofer, are there one or two sets of positive and negative leads. And what are the subs impendence (ohms). and what type of amp are u running.
Username: Mrrogers
Post Number: 47
ok i guess they are single 4ohms and i have a 2 channel amp which i had bridged with just one sub
Username: Nnnnick_b
Nc Usa
Post Number: 227
well first, u will only be able to achieve a 1.5 ohm load or a 12 ohm load on the amp. niether of which will work. You will have to purchase a mono subwoofer amp that is 1 ohm stable to power the three subs. To achieve the 1.5 ohm load, you will wire in parallel. connect all the positives from all the subs to the positive on the amp, and the same with the negatives. Pretty simple. But there is a 99% chance that the amp u are using is not 1 ohms stable while bridged. It is most likely 4 ohms stable. What type of 12's are they?
