12w7
would a jl 1000/1 1 channel amp be good for onme 12w7? and if so could it power two?
Username: James1115
Wilton, Ct
Post Number: 1940
yes it is good for the 12 but if you were gonnna get 2 and underpower them why dont you just get the 13w7? perfect match with that amp and willl get very loud and sound great at the same time
Username: Gino0809
so would one 13w7 sound louder and better then two 12w7's?
Username: Subfanatic
Walton, Ky
Post Number: 941
no
Username: Gino0809
Post Number: 7
so then why not jsut get 2 12w7's?
Username: Rds11
Louisville, Kentucky
Post Number: 96
cheaper, you would need two amps to give those guys enough power or a more powerful amp. those are dual-3 ohm subs and they handle 750 watts (the 12s). The 13 handles 1000.
Username: Gino0809
Post Number: 8
so how much cheaper would you think it is?
Username: James1115
Wilton, Ct
Post Number: 1943
ok well if you were to get 12's you would need about 1500-2000 watts or if you were to get 1-13 the jl 1000/1 would work perfectly. it will be much cheaper depending on the amps you go with but if you are considering the 1000/1 then I would go with 2 of them for the 12w7 and one of them with the 13. either way the 13 with a 1000/1 will be enough bass for you unless you are competing. what I would do is 2-13w6v2's with a 1000/1. but thats me
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 78
i just finished my install of a JL13W7 and 2 500/1's (instead of a 1000/1 which is the most typical setup) and its more then enough bass.
it will almost cost you double the price of a 13 and 1000/1 to get 2 12's and 2 1000/1 (depends on where you get them from)
Username: Gino0809
Post Number: 9
would the 2 13w6's sound better and/or louder than the 13w7?
Stockbridge, GA USA
Post Number: 80
they wouldn't be louder i don't think, but they would prob have better sound quality
Username: James1115
Wilton, Ct
Post Number: 1946
yes they would be louder! and the SQ is all opinions. they both have great sq some people like the w6v2's better then the w7's http://www.caraudiomag.com/testreports/0403cae_jlaudio/ read that.
Username: Gino0809
Post Number: 10
brandon, how much did you get your amps for and how much?
Username: Gino0809
Post Number: 11
brandon,where and how much did you get your amps for?
Username: Rds11
Post Number: 99
personally I like the W6v2's better because they are cheaper and almost as good as the W7's. the money is a better compromise in my book. Plus the 12" W6v2's handle 400 watts so 1 JL 1000/1 could power two of those perfectly.
Username: James1115
Wilton, Ct
Post Number: 1952
I would go 13w6v2's if I was you though off of that amp:-)
Username: Jonathan_f
GA USA
Post Number: 3473
The 13W6v2s would have an SPL advantage when comparing two of them to 1 13W7, it's a sheer surface area advantage by a large margin, and the 13W7s extra excursion can't outdo that much displacement. In ported enclosures you have to especially consider surface area as you'll usually never reach full linear excursion in a ported enclosure unless you're pushing much, much more than recommended power or running a sub under the tuned frequency. Like said above, SQ is subjective and both are great, I prefer the W6v2 over the W7 for sound quality purposes as W7s can be a little overextended and boomy on certain material. Just a preference, not a recommendation, it's up to your ears.
Stockbridge, GA USA
Post Number: 83
i got my 500/1's from HiFi Buys (Tweeter) for $489 a piece, with their 3 year warranty.
but you can find them cheaper online.
Username: Akula_class
Post Number: 12
12w7's do just fine with 500/1's check out JL's site and you'll see what I mean. So if you go with 2 12w7's get 2 500/1's you don't have to have 2 1000/1's.
Walton, Ky
Post Number: 954
also with running 500/1's you wont haqve to worry about upgrading your electical system, they only have a 47 amp draw
Username: Biglou
I just bought 2 13 JL W7s. I have two Rockford 2002s pushing them. What size compacitor do I need?
Stockbridge, GA USA
Post Number: 94
get like a 20-50 farad cap, allumapro's are nice. or get a BatCap, thoes are nice as well. but if your getting a cap to help with electrical problems, they won't replace an alternator
