2 JL 13w6v2's... Sealed or Ported?????
Username: Suleman36
Post Number: 249
I upgraded from the 12w6v2's in a sealed jl box to the 13w6v2's sealed which im getting this week. What whould sound better. Sealed or Ported???
p.s. Itll be powered by 2 jl 500/1's
Username: Invain
Michigan United States
Post Number: 1626
Well, the first thing I would say is you don't need 2 500/1's. 1 500/1 would be just fine for the 13w6v2. Now, if you are gonna run both to it, I'd go sealed.
2 JL 13w6v2's... Sealed or Ported?????- 2 13w6v2's...
Username: Sancho886
El Cajon, CA US
Post Number: 97
i think hes running 2 13w6v2's
Username: Suleman36
Post Number: 250
Hey Joe im running 2 13w6v2's. I whould like to go ported but wanted to know whats the best option. It comes in a sealed and i whould have the ported box built to jl specifications.
Username: Taylor17
Kopperl, Texas
Post Number: 943
I would go sealed... I just like the way sealed boxes sound.
Username: Suleman36
Post Number: 251
What kinda music do you listen to taylor?? I listen to alittle of everything. Mostly rap and electronica and some rock.
Username: James1115
Wilton, Ct
Post Number: 1944
go slot ported!
Username: Suleman36
Post Number: 252
Hey james..thats what i wanna go with. Slot ported!! James find me a good componant set to blend in nice with that setup. Budget is under $300.00
Username: Nitescort
going from 2 12s to 2 13s was wasted money.
not enough benefit to warrant it.
Username: Invain
Post Number: 1718
2 13's will have more displacement than 2 12's, equaling more spl. Since they're are good quality, the size difference shouldn't affect sq very much at all. The 13 should be able to move just as well as the 12.
Username: Suleman36
Post Number: 290
cant wait to try these slot ported running off the 2 500/1's
