Amp help please<<<<<
Username: Volsrule2069
Post Number: 20
alright on the side of my amp i have 2 nobs taht say HPF and LPF and i can adjusst them by turning the nobs, there is also a switch, you can have the switch pointing to one of 3 things: HPF LPF or FULL, i keep it on full bc thats what it was one hwen i got it, but i found that when it is on HPF it is a lot louder and deeper, what does HPF and LPF mean? and would it be bad to keep it on HPF? would taht mess anything up?
Username: Taylor17
Kopperl, Texas
Post Number: 978
It just has to do with the frequencies you're sub's play.
Username: Solacedagony
New Jersey US
Post Number: 302
Set your LPF to 80hz, your HPF to 20hz, and the switch should probably go on HPF.
LPF = Low Pass Filter
HPF = High Pass Filter
Username: Coronababe
I am planning on buying a full system for my jeep wrangler I am going to buy 6x9 pioneer speakers for the front(240 watts),6-1/4 pioneer speakers for the back (130 watts),I am also getting a pioneer receiver(DEH-P4700MP)50x4 and I was wondering to get the best sound&bass out of these speakers what should I do? should I add an amp,and if so what kind? if not than what do you prefer that I do? and is my overall speakers and receiver pretty good picks?
