Alternator Upgrade with factory electrical...??
Username: Tragedy
San Jose, CA
Post Number: 102
I just upgraded to a 170amp alternator from a 90amp alternator.. Is there anything i need to worry about with the extra juice? Ive upgraded all my grounds and power wires.. but is this just a plug and play type of install? Do i have to fuse the main lead going from the alt to the battery? am i going to blow any fuses?
any help is greatly appreciated..
Username: Nitescort
Post Number: 22
yes. by all means fuse the cable from the alt to the battery with a 150amp fuse.
