What size alt?
Username: Audio_fanatic
Mukilteo, Wa
Post Number: 36
Hey i was wonderin wut size alternator u would recommend for my car, u can c my system if you click on my name. Thanks for tha input, and if you could, how much do u think it would cost?
Username: Invain
Michigan United States
Post Number: 573
150 amp should be fine IMO. Your running about 800 watts rms right?
Mukilteo, Wa
Post Number: 37
yes, thanks for tha inpput
Username: Gakel05
Florida Usa
Post Number: 8
can someone give me a few good name brand altinaters i could upgrade to, i need 200volt or up...i have 3 jl 1000/1 amps i need to keep powered, i heard mean green is a good one, is this true???
Username: Taylor17
Kopperl, Texas
Post Number: 964
For HO alt's, take a look at 4alterstart.com if they don't make a big enough one for you're car I believe they can custom build one.
