Solo avalanche 15" What amp is the best?!
Username: Kevints
Ponca City, OK United States
Post Number: 12
I am going to buy a avanlanche 15" but i haven't figured out what amp will go very good with the sub. I am looking at 700. 299 for the sub. SO i will have about 450 left over. Any good suggestions and comments. It's going into a 1992 bmw 325i
Username: Kevints
Post Number: 13
Is this a good pick? http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=18797%26item%3D5757906247 %26
Username: Kevints
Post Number: 14
Username: Kevints
Post Number: 15
ORION 1200D
CLASS D MONO AMPLIFIER
1 X 425 @ 4 Ohm RMS 1 X 850 @ 4 Ohm Peak
1 X 725 @ 2 Ohm RMS 1 X 1450 @ 2 Ohm Peak
1 X 1200 @ 1 Ohm RMS 1 X 2400 @ 1 Ohm Peak
Selectable 12/24 dB/octave variable low-pass filter
Intelli Q bass optimization circuit and remote gain option
Separately adjustable, selectable variable high-pass filter with proprietary Copy/Master control circuit for RCA outputs
Copy/Master feature supports gain and crossover adjustment matching in multiple amp
Allows external bridging of two matched gain amplifiers
Switchable phase invert function
Heavy gauge direct-wire high current satin finish power and speaker terminals
Username: James1115
Wilton, Ct
Post Number: 1893
no dont go with that amp. I would go either with a orion 250 HCCA(perfect run at 1ohm), I have a PPI a600.2 running my avalanche 15 running at 4ohms and it sounds awsome. Joe Smoe is gonna be running his avalanche with a orion 250 HCCA GS.
Username: James1115
Wilton, Ct
Post Number: 1894
What is the idea wattage for the Avalanche 15? Also, any more on the 12?
