Amp choice to run my HCCA 12
Username: Jmloughrey
Farmington, CT
Post Number: 985
my choices are as follows....
Orion 6002 for 180
Rockford 551s for about 220
RockFord 601s for 275
Pheonix Gold Xenon 600.1 for 285
Username: Taylor17
Kopperl, Texas
Post Number: 1021
I would go with the Rockford 551S:-)
Username: Invain
Michigan United States
Post Number: 1698
How many watts is that sub? You should try to find an older Orion HCCA amp to go with it.
Username: Hdubb
Farmington, Nm Usa
Post Number: 1174
thats what i was thinking. the 250 hcca? or the 275 hcca
Username: Invain
Post Number: 1702
I'm thinking the 250 would match up with the HCCA subs. Not sure how big they are, but I don't think they'd need a 275. You can find lots of HCCA 250's on ebay. The better ones, G4's and GS's are a lot harder to find, but there's always a Digital Reference on ebay.
Farmington, CT
Post Number: 986
Its a dual 2 ohm sub...rated 600rms...i've desided to stay away from 2 channel amps and bridging them...this sub wants power so it'll just overheat a bridged amp in little to no time...i'm going to run it at 4 ohms as i'd rather not just an amp at 1 ohm...more of a personal preferance thing...
Also had a potential at getting a JL 500/1 for 300 shipped used for about 1 week with original paperwork and box...
Username: Invain
Post Number: 1705
Well, your not gonna over heat an HCCA amp, but whatever you want man...
