Poineer Cd Player
DaDaSuPrEme
A friend gave me his old Pioneer head unit. It still works, but the harness that plugs right into the back of the cd player is kind of messed up. He has alot of wires spliced and some of it has barew wire showing. So I just wanted to know if I can buy another harness somewhere. Its a good cd player I just want to clean the wires up because I dont know iF I could trust what he has done. Anyone have any suggestions?
Thank You
Username: Illuminator
Post Number: 90
Ebay would be a great place to find another harness.
DaDaSuPrEme
Where could I find the wiring harness that would fit a DEH-10?
Post Number: 91
Put this number in the ebay search box: 5768235207 and hit enter.
An auction should come up with the exact harness you'll need. If that doesn't work, just search for 'pioneer wiring harness' and go through the list of those to find one that will fit your unit.
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 347
Your local Autozone should carry them too. And they run less then $10
DaDaSuPrEme
Thanks for the help Jexxen and David. Before I came here I was looking to pay $21 plus shipping directly from Poineer
