Which amp to push my sub?
Username: Quiksilverx181
Debating between MTX MXA4002, MTX 342 and Audiobahn A4002T... They are all between 300-400 RMS @ 4ohm i believe. My sub is a 12" Infinity Reference sub 300wRMS @ 4ohm. Which one would you recommend for cooling, performnace, and power?
Username: Wcc
Los, angeles, California USA
Out of those 3 I will go with the Mtx 342 that will be a good combo.
Thanks, thats now 3 votes from 3 sources for the MTX 342, thats what i will go with. Thanks
