I need a subwoofer
chiller
where can i buy a subwoofer?
Username: Motoman22
Post Number: 45
are you serious?
www.justwoofers.com
www.discountjungle.com
www.ebay.com
www.audio-warehouse.com
and, of course, it is always wise to buy locally from a good install shop if you plan on wanting any kind of help later.
Username: Fryguy22
dude go to ebay you can get awesome subs there or i can get some mad cheap
chiller
thanks guys i have a subwoofer now
Username: Dr_crankenstein
It's best to buy from a local shop since some companies don't approve of online selling and your warranty will be void. Some companies allow it though, so you need to research first.
chiller
now i have got it where should i put it?
Username: Motoman22
Post Number: 66
Chiller, put it in the hands of a qualified installer...and bring your checkbook or credit card.
chiller
I've not got much cash so it's DIY for me.
Username: Glasswolf
Post Number: 813
"where should i put it?"
never a wise question to ask.
words of wisdom.
I want to buy audiobahn enclosures and was wondering whether it is better to buy sealed bass, ported bass or bandpass. I am willing to spend anything and listen to R'n'B music. Any suggestion welcome
Thanks
Username: Glasswolf
Post Number: 819
if price isn't an object, forget audiobahn entirely.
buy good subs, and have a box custom made.
What subs would you recommend I buy?
I live in the UK so I want to purchase something from the UK so that there is less shipping costs, any suggestions on what subs to purchase. I want to buy at least 2 subs.
Username: Glasswolf
Post Number: 821
JL Audio, Adire, RE, DD.. lots of good subs out there.
Audiobahn isn't one of them.
redrobin
well,u r well weired mate get a life and go 2 clives the county of kent.
Username: Its_bacon12
Post Number: 91
speak in english please?
Username: Tomt813
For the BIGGEST bang for your buck, check out
www.credencespeakers.com
These guys built Kickers for years. Now they are building speakers just like them, but with their name on them and selling them dirt cheap. I have seen a few of the Credence speakers on eBay every now and then. http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=3079259782&rd=1
