Rate my system
Username: Aaaavv
Post Number: 75
rate my system at this link
http://www.carstereo.com/installs/photo_gallery_album.cfm?galleryid=533
Username: James1115
Wilton, Ct
Post Number: 1633
nice set-up man
Username: Aaaavv
Post Number: 77
james could you please click on the rate system and rate it for me when you go to the link
Username: James1115
Wilton, Ct
Post Number: 1638
yeah sure I didnt see that.
Username: James1115
Wilton, Ct
Post Number: 1639
alright done
Username: Invain
Michigan United States
Post Number: 1359
I like the tweeters in your door. You had that professionally done, right? I'd like to try that.
Username: Aaaavv
Post Number: 78
yeah, most tweeters have a good lip om them so as long as you make a descent cut out the lip will cover every thing and they will look flush
Username: Invain
Post Number: 1362
How does it like, stay in there though?
Username: Aaaavv
Post Number: 79
you just cut the hole kind of tight and push the tweeter in there. the tight fit keeps the tweeter in place. you got to be careful when cutting the hole cause theres not really much room for mistake
Username: Aaaavv
Post Number: 80
<img>
Username: Jonathan_f
GA USA
Post Number: 3427
Love that install, very clean. I'd keep the cover over the subs for security reasons personally, plus it looks cleaner. You might be able to make a better looking baffle, but I'd keep it back there.
GA USA
Post Number: 3428
"How does it like, stay in there though?"
There is a fastener that screws in behind the tweeter, looks like this:
\_/ and the tweeter assembly is above that "V", the V is screwed through the bottom of the tweeter holder and hugs behind the panel the tweeter is mounted on.
Username: Invain
Post Number: 1376
Alright, thanks guys, I think I might try that.
Username: Aaaavv
Post Number: 82
originally i had planet audio componets jonathan. the mid bass sucked on them but the tweets sounded real nice. the main issue i had with them was that when i turned up the volume real loud the tweeters would cut out. i initially thought this was a power issue so i went to the shop and they told me it was a built in circuit in the tweeters that caused them to cut out to protect the tweeters from over heating. i thought this was some straight bull sh!t. i coulde never play my system loud with out my highs cutting out. so when i bought my w7's i bought those jl componets. initially i was afraid they werent going to fit the holes that the planet audio comps were in but they fit perfectly snug. another friend of mine just put his in flush with nothing holding it in the back
Username: Aaaavv
Post Number: 83
hey you guys make sure you right my system at this link, this is a really good forum to chreck out to............ http://www.carstereo.com/installs/photo_gallery_album.cfm?galleryid=533
Username: Aaaavv
Post Number: 84
hey guys, make sure you RATE my system at this link this is also a very good forum to check out..................... http://www.carstereo.com/installs/photo_gallery_album.cfm?galleryid=533
GA USA
Post Number: 3433
The JL tweeter has circuitry to protect the tweeter as well. Nearly all high end speakers have some form of tweeter protection to isolate it from DC voltage, tweeters blow easily. It's not a bad thing, though.
Username: Aaaavv
Post Number: 87
my jl tweeters have yet to cut out on me though. my planet audio tweeters always cut out on me, even when i only turnrd my volume up half way
i have a question for you jonathan. right now i have a crappy sony hu thats rated at 4 volts but when it was checked with a multimeter it was only two. ive been thinking about getting one of the newer 8 volt eclipse head units. how much would this help my sound quality. i know they have alot of great features, but will it make a big difference on my SQ?
Username: Aaaavv
Post Number: 89
bump
Username: Invain
Post Number: 1428
I don't think you'd notice a huge difference in sound quality, but some possibly. Going from 2 to 8 will definitely cut down on any engine/alt or other noise in your subs though, if there's any at all to begin with.
