8 Inch sub
B-real
I just got a dodge dakota quad cab which has absolutely no room behind the rea seat. I want to do a staealth install and I think an 8 inch sub is the only thing I can fit back there. I was thinking of the Kicker L5 or L7 beacause of their greater surface area for an 8. Anyone have any other suggestions for an 8 inch sub? Maybe a JL W3 or W7? any others?
Username: James1115
Wilton, Ct
Post Number: 1671
stay away fom the kickers if you want any sort of decent SQ. I would go JL or image dynamics need very small enclosures which should work out well for you. Look into JL's stealth boxes I think they build one for your truck. go to www.jlaudio.com check them out cause I think you can do 1-10.
