Size cap
Username: Point78
El cajon, Ca
Post Number: 23
i have a 2 channel 1000wat amp with 2 channels each channel putting out 500 watts that means i want i 1fraud cap right?
Username: Marley289
Post Number: 137
.5 if it is 500 rms or 1 farad if it is 1000 rms, you could still get 1 farad but it wouldnt make a difference if its only 500 rms.
Username: Taylor17
Kopperl, Texas
Post Number: 937
Yep, you usually only need 1 farad for every 1000 watt's. With cap's, you go by the amp's peak output as well. So if you're amp is 2000 peak, you'll need a 2 farad cap.
